Hi, I figured out yesterday that my bottom coil isn't getting what it needs to create a spark. So I decided to remove the flywheel and investigate further. I removed the shaft nut and the pull-starting plate(and bolts). I bought a puller and grade 8, 3" bolts but after trying everything(heat, liquid wrench over night, etc...) the flywheel wouldn't budge and finally the threads of one of the bolt holes in the flywheel just ripped out with the bolt. Am I totally screwed now due to the stripped hole & what possibly am I looking at that is causing this flywheel to be so stuck?
