87, 89, 93 octane
pursuit2460
I have a 93 johnson 225. What is the octane I should be running. 87-89-93. thanks
JB
Re: 87, 89, 93 octane
What Daddy said.
Dhadley
As long as your running it stock, as produced, 87. If youre running small bore heads, 93.
pursuit2460
Well I bought the boat used 4 years ago it was and ex-marine patrol boat. I dont know what small bore head are but thanks for the info.
budsbud66
the only real way to tell is to warm the motor and do a compression test. that way we can pinpoint what you need.
Dhadley
Whats the casting number on the heads? I doubt seriously that the Marine Patrol changed the heads.
2even
Dhadley, which motors have small bore heads that would fit his motor. Or are you refering to 150-175 heads and what is the advantage.
pursuit2460
the # on the heads are 340839 also comp. is 100-95 on all pistons
Dhadley
On the big bore 3.0 liter V6 loopers (1988 & newer) we run the 2.7 heads (1986 & 87) to gain power. But at that point we run 93 octane. It shows up best on performance type boats.<br /><br />You have a Scarab, right? It may help but I don't think the gain would offset the trouble & $$$ of putting 93 octane in that big of a tank.
2even
Dhadley, thanks for the reply. It was only for info that I asked the question, you are correct about the tank !!!. By the way con-grats on your 10K post, I also thank you for your contributions.
1ncornett
i have a j60tletd and thought to always put 93 octane. now that i've read this post, i'm questioning that. which octane for my motor?<br /><br />thanks for your input.
