Re: 87 force 125 low speeds with open throttle
update after trying again this weekend...
we sprayed some carb cleaner, however, still only got up to 10MPH on the way out of the river. HOWEVER, after trolling around a bit, a few stops and starts while drift fishing, we got 20MPH on the way back to the dock. is this indication that the carb cleaner worked? this motor used to run closer to 30MPH. will try replacing fuel pump next. i also need to get compression test tools. will update again soon. thanks for the help guys.
