Pony
- Jun 27, 2004
- 4,355
Having only had this 25hp johnson for a month or so now, I am still trying to make sure it is all running the way it should be. So far I did a decarb with sea foam ( spraying a 1/4 bottle through carb when engine was warm and running...followed by spraying a liberal amound into the cylinders through the spark plug holes when semi warm and waiting about an hour or so before i restarted it. then put new plugs in. It seems to run great. I noticed last time out that the first 1/5 turn or the till handle doesn't alter the carbs butterfly in anyway. I then looked further into this and see that at wot the carb butterfly barely makes 45 degrees to horizontal. I thought that to be odd given that performance seems so good. The butterfly should be horizontal correct??? I think the thing (no idea of technical name) along the throttle linkage with the screw and spring on it was off by a little bit, which is prolly why i had no throttle response for the 1/5 turn of the handle. I moved that so the the butterfly begins to move when the throttle begins to move on the tiller handle, and the butterfly now opens to horizontal at wot...Did I do the right thing, and is it supposed to be horizontal????
