Re: 87 suzuki 75 hp acceleration problem
the sensores on your engine normally brings the rpm down when something goes wrong or when one of the sensors go bad, so you need to check a couple of things, the oil level switch in the oil tank, your water flow switch and the oil flow and water flow sensors ...
