History here...This is a friends boat. I took a look for the first time last night.
Engine was surging a higher speeds and would always stall when put into gear. Then finally wouldn't run at all...he had lost spark. So he pulled the boat and...
Replaced:
Stator
Powerpack
Rect/Reg.
Rebuilt Carbs
New fuel pump/lines/tank...
He spark on all 4 now.
Now the engine runs again, but still doesn't like to go into gear without stalling and still surges (and sometimes boggs down but then sometimes comes back up to higher RPMs) at higher RPMs.
Now the plugs keep fouling. The cylinder heads are ice cold even after running at 1500 RPMs for 20-30 minutes in the water. So I told him that I thought that either the tstats are stuck open or there are no tstats at all. And that this would definitely cause a poor idle, fouling plugs and that the fouling plugs could definitely cause the surging. What do you guys think?
Also we did a compression test (on a very cold motor) and the results were
115,120.115,95. The 95 number isn't great and told him that this COULD be the problem but I told him to decarb and see if the numbers improve. Because if this thing has been running cold for a while I am sure that is a ton of carbon buildup possibly contributing to low compression in that cylinder (ie stuck rings).
Comments, suggestions?
Replaced:
Stator
Powerpack
Rect/Reg.
Rebuilt Carbs
