zool
- Aug 19, 2012
- 3,433
Re: 88 Alura
Not sure what size Alura you have, but it looks like the 35..which is 13000lbs dry. Honestly, a sbc is pushing it a bit, but the problem you may find is GM stopped producing the 8.1 block, so whats around is whats left. Im not sure if the 6.0 comes in RH/LH configurations, but you can check on that, it produces abouth the same hp as the 8.1, but much less torque, and less efficiency. Most likely they are pricing the 5.7 because of limited choice, and you had 360's in there.
are you specing the 5.7 classic carb? or the captains choice mpi? or something between...
