- Jul 18, 2011
- 18,499
Arawak,
Aluminum fuel tank, right?
It does not appear that your method of fuel tank installation is proper and in compliance with USGC regs. (correct me if I am wrong about what I see. . .) If foam is used around the tank, it must be adhered to the tank with a strong bond, so that moisture could never come between the foam and the tank.
If foam is not used, then the tank must be supported in a way that open air space is all the way around the tank.
It seems like you are going for a combination of the 2 primary methods, which will not give proper resistance to corrosion of the aluminum.
you could still foam in the tank from where you are with the foam, but the technique will have to be a bit creative though.
