Scott06
- Apr 20, 2014
- 7,308
If your idle passages are clogged then there is no fuel going to it. Any hangin up linkage will not help needs to move freely as a closed choke will eventually foul the plugs and kill the engine.I set the choke when engine was cold so that flap was barely closed. I did notice that choke is hanging up a little bit. I still do not understand why engine would die when putting it in the neutral position. Rebuild kit is on its way. Thanks for your support.
What does your fuel filter look like. Most of these issues are from boats sitting and getting contamination in the fuel system
