88 Sunray- Deck Transom and Stringers oh my!!
Jbasham
Thanks Woodonglass that's what I was hoping to hear.. I was worried there was something wrong with my resin! It makes sense though because its hot here and the humidity is almost nonexistent
Baylinerchuck
I tried to reply to your post yesterday but the iBoats server was having issues....or I was, lol. MEK will also soften the resin so you can layup more glass and doesn't dry as fast as acetone.
Woodonglass
You should know that the absolute best method for laying glass is to lay the next layer when the previous layer is still a bit tacky. This is called wet on wet and is the best way.
Jbasham
Thank you Woodonglass and @baylinerchuck
So do I need to coat the transom with resin before I spread the PB for install?
Woodonglass
You ALWAYS want to pre-coat ALL wood prior to installing. If you don't the wood will soak it up and cause resin starved laminations.
Jbasham
Yeah thanks I just read back through your post and seen that. I just finished coating it.
Jbasham
I'm thinking of using Woodonglass method of smoothing filets with wood spoon dipped in mineral spirits. Just thinking the mineral spirits would affect the resin when laying glass over it??
Jbasham
I got the transom installed last night. It was quite the job. I started with 1qt of PB and half way into spreading it on the wood I realized I needed at least another quart! So had to jump out of the boat to mix another batch. Was really hectic but got it done!
Today I got all the filets in, it took about 2 quarts. I think I need to get more resin already!
Jbasham
So I just saw the Filet around the bilge drain cracked... Too much heat transfer into the brass drain?? Or what's going on here?
Should I grind this back out or Is it ok to just tab my glass over it?
Baylinerchuck
It's the resin shrinking as it cures. I also experienced this in really large fillets. I just made another batch of thickened resin and forced it into the cracks, then glassed over it. This was the primary reason I started putting 1/4" chopped strands in my thickened resin. I never had a shrinkage crack after that. 1/4" chop also adds a ton of strength to your fillets.
Jbasham
I thought chopped glass WAS in the recipe for PB?? I have been using the 1/4" strands for all my filets, maybe just not enough this batch...
Im going to grind it down a bit and proceed with tabbing over it then. Thanks!
kcassells
For pb/poly chopped glass should be used or it's useless. Nothing more than a resin pour with no strength. Looking at the cracking may simply be a bad batch, bad mix, over mix...? let's do it again says I!
Jbasham
Thanks for the input. I understand bad mix, but what is an over mix?
kcassells
FYI....the bilge drain is probably the most important 1st defense from water penetration. jmho. :joyous: I would take it out. Completly refill then drill out and pb/reset the drain tube.
Udder opinions welcomed.
Woodonglass
MS will NOT affect the Resin in any way. Nothing to worry about. Just keeps the resin from sticking. I Didn't say a wooden spoon. I like to use a teflon spoon from the Dollar Store.
Grind the fractured glass a bit and then mix up some "Hairy PB" This means use some pulled fibers from some scrap CSM. Fibers should be 2" long and make sure to mix the hardener and the cabosil first and add the fibers last. Also only use 1% Hardener to make it set slower and put off less heat. It'll be just fine.
kcassells
Go with the Woodman. too much of the mx can cook the mix. I'm a EEEEEpoxxxxxxxxy guy,, what do I know.
Baylinerchuck
Lots of folks only use thickened resin for filets since it smooths out way nicer than hairy PB. If the filets are too thick, they'll shrink and crack when they cure. I put chop in all my PB after I had a filet crack on me. I found out it's really not to bad smoothing out the hairy PB. I really like the strength chop provides.
Jbasham
Last night I got the first layer of tabbing on the transom. A few air bubbles, but not too bad for a rookie!
