89 40 hp vro
bktheking
Re: 89 40 hp vro
Good for 10 extra horsepower. :D
Those round rectifiers do get fairly warm, what is the concern?
mike1551
Re: 89 40 hp vro
ive replaced the power pack stator coil plugs and plug wires and you can run the boat as long as you want but when you sit it down and go to take off it starts missing at 2500 rpm let it sit for 10 minutes takes off like nothing ever happened
dish
Re: 89 40 hp vro
Could be fuel leaks,air leaks,carby problems,timing etc etc.If your rectifier goes your tach will play up,and battery wont charge.Test the amp output.
bktheking
Re: 89 40 hp vro
Sounds like SLOW is kicking in, SLOW will prevent the motor from revving past 2500rpm until it cools down, then everything starts to work again. When it does it, check the temperature of the motor with a laser thermo or your hand. Generally the rule of thumb, if you can hold your hand on the head for 3 seconds it's fine. Next thing i'd be looking at is a faulty temp sensor if its not overheating.
mike1551
Re: 89 40 hp vro
what do you mean by slow? i unplugged the temp sensor does the same thing
mike1551
Re: 89 40 hp vro
maybe this will help yall to figure it out when it starts missing at 2500 it will go up to 3000 missing the whole time bring it back down to 2400 it stops missing
bktheking
Re: 89 40 hp vro
You can try cleaning the carb, might have dirt plugging up the high speed circuit. Disconnect the rectifier and retest, could be causing your issue.
