89 5.0 Mercruiser pulley locked up - need part ID
BRYBURTON
Re: 89 5.0 Mercruiser pulley locked up - need part ID
Ayuh,... Your pictures are nothing but an Angelfire logo,...
If the Pump isn't turnin properly,.. You need the Pump....
If the Pump isn't turnin properly,+ the Pulley is Trashed,... You need Both...
As noted above, you need a special Puller to remove,+ reinstall the Pulley on the Pumps...
Why is this so hard for me to understand? The pulley is locked up. I never had any power steering issues, the issue was with the belt stopping and burning. So do I need a new pump, a new pulley, or a new pump and pulley? Is the bearing part of the pump or part of the pulley?
If you copy and paste the url into your browser, the image should come up. I don't know why it isn't working.
BRYBURTON
Ok, I think I am starting to understand now. The pulley does not come with the pump. I do need to reuse my current pulley. In order to reuse it, I have to take it off with a special puller. Should I take the pulley off with it in the boat, or should I take the whole assembly off (power steering pump and pulley) and then take the pulley off................. or am I so confused, I should take it to a mechanic?
mkast
The pump turns. The pulley is attached to the front of the pump so an accessory belt can turn the pulley, which then turns the pump. If this is difficult to understand, think of how much fun you're going to have replacing the unit. I suggest you find a mechanic.
BRYBURTON
I just want to be sure that I need a new pump, and I can reuse the pulley. I suppose the pump is the reason the pulley is not turning. I am ok, though I still would like to know when to pull the pulley off (in the boat, or out of the boat).
mkast
Remove the pump, take the pump, pulley still attached to the pump, to an auto parts store. You don't have the puller to remove the pulley. The replacement pump should have a new pulley on it. It can't be much simpler than that.
BRYBURTON
Thank you very much. I will give it my best.
Ayuh,.... I can Agree with That....
BRYBURTON
Here are my results of trying to replace the power steering pump myself......
I'm taking it to a mechanic.
Friday morning I began working on it at 7:00 a.m. It was not too difficult to remove all the necessary bolts and hoses. It was difficult to remove the pump from the mounting bracket(s). It took me as long get the pump out as it did to remove all nuts & bolts and hoses. I took it to Advance Auto, found a replacement, $50. A couple of problems. It did not come with a pulley, so I had to buy a pulley puller/installer ($30) to remove my old one and put on the new pump (they did not have one to rent). It did not come with studs for mounting the pump to the brackets. I easily removed the pulley from my old pump, but when I put it back on I was never sure if I had it on all the way. I was expecting it to bottom out, but it never would no matter how much I strained to push it on farther. I began to remove the studs from the old pump. The nut on the studs were larger than 11/16" but smaller the 3/4". I bought tools, metric deep weld sockets that I did not have and an 18mm wrench. The nut was too small for a 17mm and too large for an 18mm. It made no sense whatsoever. I did manage to eventually remove one of the studs with an 18mm. I took the stud to a store to see if I could get a new set. None at Napa, none at Advance, none at another auto parts store. But, the last place did remove the second stud from my old pump by forcing an 11/16" socket. The studs seemed to be the right diameter for my new pump, but something wasn't right. They seemed to be going into the new pump cross-threaded, but they weren't cross threaded. I tried the other side of my stud (one side was coarse thread and the other was fine thread). Neither would truly start by hand. Well, I forced them anyway and my first one seemed ok. I managed to get it flush with the pump. My second one was almost flush when it seemed to strip, and was suddenly loose. Not good for mountaing a pump. So essentially I ruined the pump since I can't get studs in it, I can't tap it since I can't use larger studs to replace it.
I'm giving up. Taking it to a mechanic where he says he can find a better GM pump, hopefully it comes with a pulley and studs. I spent 7 hours removing the pump, driving and getting parts, work on pump, driving to get tools, work on pump, driving to find studs, work on pump. Ruined pump. All I accomplished was I removed the pump, I have some new tools, and wasted a lot of money.
At least it will still be cheaper than paying $500 for a mercruiser pump.
