- Jul 23, 2011
- 52,171
Re: '89 Bayliner Avanti restoration - where to start?
no need to drill, epoxy, and re-drill. simply pick up a transom connector for a bilge hose, make the hole big enough in the ply for the connector and a few layers of glass, recess a bit for the connector flange so the top of the flange is even with the top of the ply. then after glassing, cut off the connector to about an inch long, bed in with 5200
this way you can buy standard bilge hole plugs and plug the cooler if you want.
thru hull connector - iboats
Seasense Baitwell / Bailer Plugs - iboats
When I did my coolers for the boat, I used a layer of 1/4" ply on the bottom over the foam with a 3" hole to make the recess for the connector
