brandon6.0
- May 19, 2012
- 47
Well running into a few problems. My friend has a 89 Johnson 150 on a bass boat. Said when he first got it he rebuilt the carbs him self and we just changed the plugs and new gas with 50.1 mix 2 stroke oil.
He said it was running good when he first rebuilt the carbs. Well we took it out for a ride and played hell getting it started. Finally she fired up and all we could get it to do is idle along in gear. Any more throttle and it would stumble and die. Hit the key and it would fire right back up like a brand new one. In nuetral you can get it to rev to the max. But in gear all u can do is idle along. What do u guys think? I took all fuel lines off tonight and i had good pressure and fuel coming all the way through the fuel pump and out to carb inlets. Does this mean the fuel pump is good? Spark seems fine on all coils as well. I really think it is a fuel issue. Could the low/high idle screws being off cause this as well?
thanks guys!
thanks guys!
