Re: '89 mariner,4cyl,45hp,no fire while spinning starter
bassinbill, the fly wheel itself is a big part of the ignition system. Try taking it off again and cleaning the hole where it goes on the crankshaft. Also clean the crankshaft real good. The flywheel must make good continuity thru the crankshaft for the system to work right. Whilt you've got the flywheel off check for loose or broken magnets.
