I have a 24' CC w/ twin (CR), 89 Merc 150's. These are low hour, good running motors. Today I was running at 1200-1500 rpm on one engine in 4 ft water on mild trim. Water pumping fine. I lowered & fired up other motor and it was OK for a few mins. and then cut out and would not start. At the dock I found that the the flywheel is stuck solid. Motor has NEW impeller and plenty of oil in the tank & line to pump. Any ideas? I heard no noise at all, she just quit. Thanks, Chris
