89 Merc. 25 hp rough idle and dies at half throttle
DU118
Having trouble with my 89 merc. 25 hp outboard. Problems started with a failed fuel filter that allowed sediment into carb. Tore carb down and cleaned, new fuel tank and fuel/water separator and new plugs. Motor ran good at first startup after carb rebuild but then developed the problem of falling flat on it's face at anything past half throttle. Now getting fuel out of the exhaust at first start and am wondering if I have a needle valve problem. All help and advice is appreciated and thanks in advance.
mellowyellow
Re: 89 Merc. 25 hp rough idle and dies at half throttle
welcome aboard,<br />sure sounds like some crud is keeping the needle<br />and seat from working properly. float is sticking<br />causing it to flood. squeeze primer bulb and I<br />bet u see fuel flowing out of front of carb.<br />good luck,<br />M.Y.
