I have a 89 Mercruiser 350 I/O that suddenly died while under power tonight. Was cruising at about 12 mph and all of the gauges were reading normal. All of a sudden the motor just shut off. Couldnt get it restarted and noticed that the oil pressure gauge wasnt moving like it normally does when I tried to crank it back over. Ended up getting a tow back to the slip and didnt mess with it too much. The motor was running fine with no funky noises. Do carbed motors cut the power if the oil pressure sensor fails? What else should I check in the morning?
