- Jul 23, 2011
- 52,054
did you get fuel pressure?
Not yet, work keeps getting in the way.did you get fuel pressure?
4-7psi at the carbHeading to the boat, what should the pressure be?
5.5psi4-7psi at the carb
also check the opaque yellow line from the fuel pump vent to the spark arrestor to make sure there is no fuel in that line. if there is, your fuel pump has failed.
No fuel in line5.5psi
here is a listyes sir, on of the first things i went after along with wires
your compression is goodgood morning,
anything else you can think of? I'm stumped
Yep, thats this weekends project.Don't just drain the filter. Change it. And remove the sending unit and siphon the water out
This is progress
