Re: 8HP Won't Start
60 lbs of compression is not good enough. There's an issue if that's the best you have.
The tops of pistons are not where you need to look, if the rings are stuck, ring lands corroded/carboned up or pistons scored you won't get good enough compression to make this run worth a hoot.
