I replaced the carb.
Took out the sparkplugs and sprayed Seafoam into them. Then I had to put the motor into gear to start.
I closed the choke and it started. I put additional seafoam into the carb and it almost immedieately started purring like a cat.
I tried to move it back to netural and it would die. I tried to adjust by turning in the slow idle screw. Did not help.
The choke has to be almost completely closed to run. About a 1/16 to 1/8 opening only
When I open the choke it up more, it wants to die.
The slow idle screw does nothing. I screwed it in completely and it had no effect on it.
Any suggestions?
Any suggestions?
