I have a lack of power at the top end of my 1976 9.9Johnson with a 15hp carb. Had the same issue with my 9.9 carb on it. I can coax the power by squeezing the bulb, but iust feels like it is off a bit from what it should be. When it is cold it seems screaming fast then after running for a while it appears to loose something. Idles perfect, hole shot is great, just will not max RPM randomly. Carb has been cleaned completely and rebuilt. Spark plugs are new and gapped to 0.30, compression 103/105, new coils and point set to 0.20 armature plate has no wobble. Could it be a carb float. I leveled it with the gasket? I pulled the welch plugs on the carb and cleaned the passages. Any ideas how to get my top end power back?
