9.9 force smokin/ slipping after runing wot 4 while
TRIGCOVE
Hello all. new to the outboard scene and NEED some good ole advise! i got a 99 gamefisher 9.9 used. guy i bought it from says he used i 2 times then stored it.(i believe him the prop n motor r very clean). problem is this- took the boat out in fresh water ran it at wot for bout 1 hr no problem. then all of a sudden it felt like the motor was goin in neutral. ( like a bad clutch slipps in a car) but only in little spurts. so i slow r down to try n limp it in, starts slippin real bad, and smokin(white smoke). so i killed er off and rowed. now i got a 12 ft aluminum v hull boat wheighs bout 100 lbs. 6 gall feul cell, and me n my buddy combined weigh bout 400 lbs. the motors about 65 lbs. now some people told me the plastic prop that comes with it from the factory is good 4 300 lbs. am i overloading the prop and thats whats slippin? ive been told that props sometimes slip inside the bushing. i dont know. i took prop off and used a pair of vise grips to try and turn the prop on the bushing but no go! also. whats with the smoke! 1st time runnin it (only ran it twice) no smoke ran hot. changed thermostat and all good. 2nd time motor feels like its slippin and smoke out the wazu! any help on this troubling matter would be appreciated. thanks trig. PS i checked the gear oil in the lower unit and it looks good. no metal/water. so i dont think its the gears, or i hope it aint!
time out
Re: 9.9 force smokin/ slipping after runing wot 4 while
I have a 9.9 force motor with low hours too. and I too lost the forward direction in my motor. After taking apart the lower unit, I found the forward gear to be my problem. It looks like the forward gear and clutch dog are copper brazed together from the factory. On my motor the braze broke and the gear slips on the clutch dog. I don't know how to fix this and I sure don't want to buy a new gear they cost about $300.00. good luck.
FlyBoyMark
Ensign
trigcove...I live near you here in Weston...email me at flyboymark@aol.com I've owned a bunch of these engines, I think I can help you out, been welding 20 years.......the fishing is hot at Sawgrass. Caught twenty bass in 3 hours last friday...and a fat 4 pounder in my backyard lake today.......
time out
I am no expert, just tring to help another boater!!!
D
DJ
Guest
Time out,<br /><br />You done good, you figured out what was wrong with yours and probably with Trigcove's too.<br /><br />Trigcove,<br /><br />The thing that bothers me is the "smoke". NOT NORMAL!!! Was the water pump impeller changed? What is the compression-now?
