floridaboy969
- Aug 16, 2012
- 5
I have a 1988 9.9 Gamefisher by force model #225.581990 the problem im having is in neutral it pee's fine, as soon as you put it in gear it stops pumping completely, i have replaced seals on the water line, pump housing, gasket and the impellar, the key is in the impellar fins are the correct way, i am running it in a 50 gallon tank, dont understand why it pumps so well in neutral but nothing in gear any help would be appreciated.
Thanks in advance, Darien
