Re: 9.9 HP Problem
What is your model/serial? Model information is in the format NS9.9B2 or NSF9.9C, etc.
You likely have either a bad base gasket where the powerhead joins the exhaust housing (causing the carb to breathe exhaust when the cowl is in place), or a restriction (such as a wasp nest) in the air intake of the cowl, causing a lack of air when the cowl is on.
