RRH31978
- Apr 22, 2018
- 22
Had some issues with the voltage regulator and stator. Voltage regulator melted a few wires together mainly just the wires from the stator. ( 2 yellow wires) I tested stator and it tested .21 ohm the range is .16 to .19 so figured the stator is shot as well. Planning on replacing voltage reg and stator but not sure if I need a 9 amp or 16 amp stator. And does this effect the voltage reg depending on which one I choose?
I was planning on getting a CDI stator because of heat issues that I have heard about with the OEM stators. While I was digging around on the motor testing the stator I noticed that the wires coming off of the trigger are a little bit dry rotted so I figured that I am going to replace the trigger as well, while I am in there. Just do not want to have to do it after I do all of this.
I did not think of this before I ordered the voltage reg so I got Quicksilver 8M0084173 voltage reg.:facepalm:
Outboard is a 2003 Mercury 90hp 2 Stroke Model# 1090412AD Serial# 0T788447
