Re: 90 hp lower unit oil change question
pretty simple really, but a manual will certainly help, a basic rundown is: get a suitable contaner to drain oil into, remove both plugs, the lower one and the top one, drain all oil, look for any suspicious metal bits in the oil and on the magnet, buy two bottles of the correct oil, fit pointy end of bottle into lower screw hole and sqeeze bottle untill you have squirted as much as you can in, get the second bottle and repeat untill oil flows out of top hole, replace top screw, the seal created will preven too much leaking out the bottom, refit lower screw and your done, it also pays to replace both washers under the screws.
