91 225 johnson 1 low cyl compression
litwor
have 85 lbs compression in all but one , it has 70 . repair man says it's still ok to run , and it seems fine , am thinking of a 2001 225 oceanrunner to up grade, any opinions ? how much does the 91 with 25" shaft weigh ? can't find it anywhere ? Does the 2001 with carb's get as good mileage as a yama or opti with direct inject or close ? I'm worried about evinrude di from the war stories ? gonna think about it till fall then decide . I don't want to change out all my control's so that" why I'm leaning towards the oceanrunner ps all gulf of mexico use and that 91 still pushes my 22 mako right along !
tashasdaddy
Re: 91 225 johnson 1 low cyl compression
nada boats, outboards. you can find the weight.
