Re: 91 Evinrude 140 Problem?
I did use a needle gap tester and also made a homemade tester to see all 4 at once, all did show spark but once a timing light was hooked up and motor was put into gear. The one coil was dropping out, I switched that coil to another piston and that coil did the same at that one also , just nought a new coil and will be trying it out tomorrow. Il get back asap with more info,I really hope this coil was my problem, the coils are only a few months old . It also has a crack on the back plastic filling
