91 Johnson 30 idles but will not accelerate
fireman57
Re: 91 Johnson 30 idles but will not accelerate
Hope everything is fine. Just because your problem got taken care of don't forget to keep participating here. Good to have more involved members.
Jim Hatch
Hey Fireman,<br /><br /> I'm just back from a test run on the lake.<br />Success!*G* Rest assured I will leave this fine<br />site in my favorites listing and visit often. I<br />may even be able to offer the occasional tidbit<br />based on my recent experiences. Thanks so much.<br />Warm regards, Jim
Jim Hatch
The aftermarket unit I got was $115. Regards,<br />Jim
rjohson
I HAVE A 84 COBIA ODDESY 3.0 MERC CRUISER ENGINE, IM EXPERIENCING THE SAME PROBLEM JIM WAS EXPERIENCING. MY ENGINE IDLES OK, BUT IF I GO ABOVE 2000 RPM THE ENGINE SPITS AND STALLS, MIND YOU 2000 RPM GIVES ME ABOUT 5 MILES AN HOUR MAYBE 10. I WAS THINKING CARBERATOR I TRIED ADJUSTING AIRLFUEL MIXTURE NO LUCK I HAVE A SINGLE IGNITION COIL AND A 2 BARRELL CARBURATOR. SINCE READING JIM SITE IM CONFUSED AS TO WEATHER THIS IS AN IGNITON PROBLEM OR A FUEL PROBLEM. I HAVE NEW PLUGS NEW FUEL PUMP. IM GOING TO TRY POINTS CAP ROTOR AND CONDENSER I COULD DO A OHM CHEM ON THE COIL IF I HAD THE SPECS. DOES ANYONE HAVE ANY SUGGESTIONS? BY THE WAY JIM CONGRATULATIONS YOU ARE VERY DETERMINED.
fireman57
Welcome to iboats. You need to start a new post in the Merc forum. Please lose the caps as it seems that you are shouting.
