Hi there everyone-
I picked up a used fuel pump to replace my fuel pump that I broke the outlet barb off of replacing the fuel line. I got it on ebay , the part # matched the fuel pump body according to crowleymarine. I'm reusing both of the alumining casing parts from my original, just using the plastic pump body off the one from ebay. The problem is the plastic fuel pump body on the new one I got is black instead of off white that my original was, and its built a little bit different (the way the inlets and outlets are shaped). Everything seems to line up fine otherwise. I'm just wondering if this will be an issue or if I'll be OK rebuilding it this way. I got a rebuild kit so I'm replacing everything inside.
I also have a second question, I tried replacing the 3/8" fuel line on the outlet side of the fuel pump to the fuel filter with some 3/8" fuel line I got at autozone. The problem is from the filter the line has to do a 90 bend to the filter and I cant get it to fit without kinking the hose. Everything is so tight in there(thats how I broke the barb on the pump). I'm thinking if I use the grey poly 3/8" hose that I have some extra from my primer bulb fuel line it will be able to bend more in there. Is that ok to use inside the cowling?
Pic:
Any help appreciated!
Pic:
