Though I've read several posts here about 70HP Force outboards, I still don't think I understand completely whether this motor is supposed to have a 'pee-hole' or not... My particular motor is a '92 model, and the only place I've noticed water being expelled is through the 3 little 1/2" or so holes on the casing between the powerhead and the lower unit. When I'm on plane, water pulses out these three holes, but it doesn't seem to come out at all when I'm just idling. I have noticed that when I pull the boat out of the water, a little 'pee-stream' comes from what would seem to be a pee hole closer down to the lower unit.... I think this particular pee hole would be under the waterline when running, so maybe it's just peeing underwater.<br /><br />Also, my boat doesn't have a horn, so I'm not sure if there would be any temperature warning on my motor... I've heard talk about a water temp sensor being added, so maybe someone could elaborate on that as well..<br /><br />Thanks!!
