Re: '93 Johnson 90 HP- no reverse
There is a critical adjustment of the shift rod length that should have been checked when the gearcase was removed for the water pump replacement. If the shift rod turned when the gearcase was removed or installed, the adjustment is out of whack and could affect the gear shifting. <br /><br />Have a QUALIFIED person check the shift linkage for slop and for correct adustment. Each time you "grind" going into reverse, you are removing metal from the gear and the clutch dog, and they are expensive to replace.
