I have a 94 40hp Force. The motor started to tilt all the way up on it's own. Sometimes in the garage sometimes trailering. To get it to go back down you had to hit the up switch. Then it went down too fast. Then it seemed to work okay.
Now it will tilt down but not trim down the rest of the way.
I plan to check fluid level, flush air and then check relays and all three switches.
Anything obivious to anyone?
Thanks
Thanks
