Blizzmet06
- Jun 6, 2019
- 30
Got a ‘94 Malibu ski boat with 5.7 350 EFI last fall. Had sat for 10 years but seller got it running and would idle and go up to 2500 rpm no problem. When I got it I Cleaned out the vst tank and got the rpm up to wot no problem. Never got up to temperature and found that the thermostat was installed improperly and was getting water all the time. Straightened that out and now the idle has dropped from 750ish to 630ish and will stall out. Also had it on the lake for a run and would get to about 3500 rpms and that’s it. Seemed to run good at higher rpms just not idle. Temperature was always 150-175ish depending on how fast I was going. I’m not sure if I burned out of all the old fuel or if the tank has a screen or filter. I replaced the fuel/water filter already no change. Start of the year I filled the tank with fresh gas after winter. Maybe less then 5 gallons were in it previously.
Thoughts on on where I should start?
Could the VST be clogged again?
is there a screen or sock in the tank?
