94 wellcraft eclipse 196s steering cable
gaboy40
Hey guys I’m about to replace the steering cable on my 94 eclipse 196s. It has the 4.3 alpha 1 stern drive. It’s gotten very hard to steer and everything I’ve read points to this cable. Trying to get some information on this part and make sure I order the correct one! Any suggestions or advice would be very much appreciated thx
Yegboats
There should be a number stamped into the plastic jacket of the cable. You can get this# and figure out what You need. Usually a whole steering kit that includes the helm isn't much more money than replacing the cable alone.
  • 1476445374_Seastar_Solution_steering_cable.pdf
Chris1956
You will want to disconnect the cable from the power steering ram, and check it. Those Alpha power steering units often have the cable seize in the tube. Usually you can clean and relube it...
gaboy40
Thank y’all I’m about to look into it now I’ll let y’all know how it goes
