95 efi 200
Pappyb
Moter at 5600 will cut back to 3000 rpms I think it may be in electrical when it does it it’s like snapping your fingers does it instantly runs like that 10-20 seconds then like snapping your fingers it goes back to 5600
It will do it sometimes when taking off fights to get on plane then instantly takes off. I put new plugs and fuel filter separater on. Have spark to all plugs. Haven’t checked spark when Moter messes up I never know when it will do it. Seems to be doing it mor often now
Dukedog
would start with fuel delivery.. may be mechanical pump tryin' ta go south... 'lectrical usually works or doesn't... do ya have an OEM manual?
Pappyb
No manual. But looking at ground wires today I found a yellow wire that seems to go to a voltage reg it goes behind coils. It had a bare spot Bailey touching a metal clip. I taped it up and taking it to lake tomorrow you can see where it has bin touching sometimes. The first time this boat done it is when we hit a big wave.
Pappyb
Thanks for the reply. If tape on wire doesn’t do it I will check pump. Can you tell me is it just one pump. Do I need to just check pressure
Dukedog
ya mighta got lucky.. send me an email addy.. will send ya an oem in pdf....
