Brock O
- Dec 26, 2014
- 60
Gents,
Last few trips the issue has occurred, It does have occasional idle problems but biggest thing is its losing WOT??sounds and runs smooth enough up to a point then just dies almost dead or to just an idle?then after a few seconds starts to take off strong again ?.I can plant it and it revs up hard and takes off clean before just dropping dead again, can sit at 18- 20knots all day no issues but any more than that problem pops up.
I?ve been over all fuel lines for leaks / restrictions
Cleaned pulse limiter?.only two years old
Carbs were rebuilt a few years ago?not leaks evident
Replaced fuel filter, last 1 replaced 12 months ago.
Cleaned tank pickups?replace pickup lines as old and had shrunken by the looks.
New spark plugs, old were coming out on the wet side not dry.
Have checked leads and coils, replaced 1 coil as rubber seem to have a puncture but no change...Ohm reading within limits in manual.
Looking at the trouble shooting next thoughts were..
linkage issue but can?t see how
Damaged VRO
Possible blocked high-speed orifice in carb although the boat is used regularly with clean fuel and regular filter changes?. maybe internal float issue.
Any ideas or thoughts are appreciated??
Regards
Brock...I'm on Aussie time...
Damaged VRO
Regards
