Sorry about the confusing title.
I replaced my 110 hp with a 1996 150 OceanRunner last year. The engine ran great, but gave me a check engine warning at WOT. Determined that the check valve (anti-siphon) at the top of the fuel tank was probably undersized, so I removed it (since the tank is below the engine). That seemed to cure the problem, but the boat started to develop a hard starting issue, so I did a de-carb, but the problem persisted. I then figured out that fuel is backflowing to the tank, so I have a lack of fuel at startup.
So I replaced the primer bulb and checked all the fuel lines yesterday. It started much better and the bulb seems to be holding fuel better. BUT, my check engine alarm at WOT came back on yesterday. It only seemed to come on above 4500 rpm, which I don't often go above, so it's not critical, but I might be selling the boat to a friend next year and want to make sure it is right.
All the fuel lines are 3/8". I tried a vacuum pressure gauge on the fuel lines, but the needle bounced around alot so it was hard to get an accurate reading, but was close to where the alarm should have sounded. (before I removed the anti-siphon valve)
Any advice would be appreciated.
thanks
Matt
thanks
Matt
