'96 lund tyee 1850 floor rebuild and foam replacement.
Sparike
I called US Composites this morning because I was curious if you should try & seal the foam if you pour to much & have to cut it. The lady I talked to said you can seal it with the epoxy resin. I still have the foam to remove from my boat & one piece of floor to epoxy, I see a test coming in the future, I'll let you know how it goes!
brunolund
that’s good to know, i’m still working on the paint. stripping about 4-6 feet at a time, so i can get epoxy primer on it before it oxidizes. very slow going with kids home all the time!! but i’m also very pleased that 95% of the scratches in the boat were just in the paint. hopefully we’ll be able to post some pics soon.
brunolund
pics of the transom going in. the aluminum lip needs to be bent back into place
brunolund
mid way through bending. i was able to get it 97% of the way flat against the wood. i will be able to lower the wood a bit, then bend flange down and flat, then lift transom wood back up under it.
brunolund
installing the rub rail to the cap first. this was held on with blind rivets. the clecos sure helped hold the shape.
brunolund
it took quite a bit of wiggling and tapping to get the sidewalls to fit the rub rail. there is a grove that the sheet needs to sit in. used lots of clecos here. the side walls were held on with solid rivets, so that’s what i used again. only “smiled” a few of them. think there was around 100 of each rivet holding the cap on.
brunolund
so after finding out that previous owner painted the boat with i assume lacquer, i’m taking it down to bare aluminum. cleaning up the aluminum with 60 grit on RO sander, and spraying with epoxy primer. then will do a bit of filler on some small dents, urethane primer and then red and grey again.
brunolund
one side done!! i’m getting much better at spraying the epoxy. i’m issuing a cheap, supposedly hvlp gun, so i don’t expect perfection, but i’m pretty happy with it so far. now to do the other side and bottom.
brunolund
finally got around to removing the rest of the old paint. had some issues with new paint stripper. doesn’t work worth a damn. ended up getting some aircraft paint remover which i should have done in the first place. it worked amazing.
brunolund
this is the stuff i ended up using. i highly recommend it. funny thing, it’s called aircraft paint stripper, but it says “not for use on aircraft!”
brunolund
got some high build primer on, more issues, but all my fault. good learning experience. now to sand and spray sealer.
brunolund
finally started taping and masking!!! got the tungsten metallic sprayed tonight, but haven’t taken pics yet. will get some tomorrow.
brunolund
finally some colour!! more peel than i’d like, but i’ll see what it looks like in the sun before i decide if i’m going to sand and respray it.
now to wait a couple days and spray the red!
kcassells
You may be able to buff out the peel. I'm not a sprayer/painter so maybe someone else will chime in.
brunolund
i will definitely try, although it’s a metallic, so i’m not sure if that’s a good idea.
brunolund
got some real bad tiger stripping on the first coat. seems like i was holding the gun too close. thought i was about 5” away. but went to what i figure was 8”, and next coats were much better. overlap was the same, seemed to be the air was blowing the stripes in when close.
