hello,
I've spent 3 weeks researching tilt motors and relays and finally fixed my tilt today. however, while swapping blue and green wires on tilt relay assembly, I accidently shorted the green wire to the red terminal on the relay assembly. After finally getting my tilt to work, I then attempted to start the motor, but it won't turn over.
it sounds like the starter is working fine, but the engine never runs. last time I had tried was 3 weeks or so ago. I'm thinking I either
1) blew a fuse when I contacted the green tilt wire to the red terminal on the relay assembly OR
2) bad fuel. when I started the motor several weeks ago, it started right up ( after sitting for 2 years or so ). when I was checking to see if it would start, I only mixed up about a half gallon in my tank. I'm wondering if maybe the fuel has gone bad ( due to ethanol, etc ) in that time. when I ran it several weeks ago, I did disconnected the fuel line and burned the rest out.
Any ideas where to check for bad fuses, etc?
thanks
Mike
PS - these forums are really helpful, albeit a little dangerous for the novice. the local marina had quoted 1200 to replace tilt motor and relay, but by reading through these posts, I was able to verify the tilt motor was good, then 'fix' the relay by repetitively clicking 'up' on tilt and tapping relay before it finally made a good contact. now it seems to work fine!
thanks
Mike
