I have a 98 dt140 fuel injected   when we gut up to 3000 plus rpm  and are on a plane the over heat warning comes on and horn goes off and drops the rpm for a split second   it does it about every 5 minutes and only at high rpms it has a good pee streem on it and has a new thermo   i am currently in the process of replacing the water pump which happens to be backordered  and have found many peixes of decayed rubber but not off the impeller
it is fine if im under 3k rpm but sounds the alarm every five minutes if over 3k
the water pump impeller is tight and pumps good i think this could be a senser
i need help checking them thanks
and this motor is a saltwater motor
thanks
thanks
