99 150 ficht spark plug problem
captknichols
i just put in new xc12pep and ran it for about 4 hours out off the water at idle or just above then it stald and wouldnt re start so i pulled the plugs and they look fried are there any other plugs i can use or is there a bigger problem thanks for the help if you can
jonesg
Re: 99 150 ficht spark plug problem
Not much expertise here for fitch models, there are websites which cater to fitch if you google them. I dunno about the wisdom of running on a hose for 4 hrs, seems excessive.
Were you standing along side the motor the entire 4 hours. If not, you have no idea what may have happened in your absence.
