roscottjr
- Jun 10, 2006
- 330
I have a 1988 MAXUM Bowrider with 125hp Force Outboard. We are planning on replaceing the floorboard due some slight rot and the transom just because we will basically be there anyway. The seats will be getting replaced as well and interior panel rebuilt and reupholstered. I just have a few questions concerning some things Im not sure about.
1. I have worked at a fiberglass shop so fiberglass is not new to me. However, coating all the wood during this restore is slightly new. I am planning on mixing the poly resin 50/50 with Acetone and then adding the catalyst to coat the wood. If I mix 1 pint resin and 1 pint Acetone, will this mixer get catalyst for 2 pint or just the 1 pint resin?
2. Does anyone know why this boat would have 2 layers of plywood originally from the factory for the floor?
3. Does anyone know if this particular boat has any flotation foam?
4. Does anyone know of a good method to do gelcoat repair on the bottom of the boat without flipping it over? Or, I would prefer to flip it over so does anyone know a good method to flip the hull over. This will of course be without no interior or cap on the boat and possibly only the transom and floorboard installed.
I am trying to get all my materials up before we start the project and I know there will be odds and ends we will have to come up with during the project but Im trying to get the main items ahead of time. This restoration is on a budget but we are not cutting corners so we need to get the largest portion of the materials before we begin.
Thanks
Robert
Thanks
Robert
