Back Agian. Recent post was boat stalling after hard run and not starting until after waiting 20 mins. or so. I have changed all fuel filters and tuned up. Rebiult carb. Still seems like does not run smooth after it gets hot or runs hard. Mind you have not had in water agian since the problem occured. Just running on muffs in my yard . Any way Ive noticed a very small amount of water which then turns to steam in 2 spots between manifold and head where the mainfold gasket meets head. One spot between 2 front cylinders and another between 2 back cylinders keep in mind it very minute and only appears after runing hi rpms for a while . No water in oil and motor does not overheat, There is no white smoke from exhaust. But my question is could this be tied in to my running problem. It will not quit in yard but loses power in water when run hard and will not restart after it stalls for about 20 to 30 minutes.of sitting.
