Re: A little water when removing drain plug
Where exactly does the water go that goes through the speedo tube?....well that is if the whole tube/hose is intact.
Just a shout out to Willie. With you on the pitot. Sasada I think you should pull the hose at the inside of the transom and plug the fitting to checkI also agree that the plug leak, while legit, would be very small.
