A quick way to measure pitch
Omineca
I have a prop that I believe to be 14x15, but although the diameter checks out, I have no idea of the pitch. Online gives me a bunch of complicated ways of calculating this, and one or two that simply don't work, so I'll have a go at figuring it out on simple first principles. My calculating will be in centimetres, but you can do it in inches if you enjoy using measurements that were already recognized as unnecessarily complex in 1795 when the metric system was introduced during the French Revolution. The result will be an approximation, but ALL methods of calculating pitch by hand are approximate.
Lay the prop, leg side down, on a smooth flat table.
Measure the radius of the propeller: it is 17.8cm for my example 14" diameter prop (I just calculated this by multiplying 7 inches by 2.54 to give centimetres). Now calculate 75% of this, which gives 13.35cm. This 75% value is the commonly accepted figure for the average amount of thrust of the prop. The diameter at this approximately widest point is obviously twice that, and we'll call it DW. In our example DW is 26.7cm.
Make small marks on the leading and trailing edges of one blade, at the 75% radius point. Measure the distance between these points on your table, as if a bright light were directly above the prop and you were measuring its shadow on the table surface. In our example we have 16.8cm for this value. We'll call it W for width.
Now measure height above the table for our marked points, in our example 10.5cm and 2.8cm. Subtract the lower value from the higher, here giving 7.7cm. We'll call this H for height.
If we now take our diameter at the 75% thrust point DW, which we recall is 26.7cm, and calculate the circumference of its circle, we'll get 26.7cm x π which gets us 83.88cm. Since your blade is 16.8cm wide it will travel 83.88cm divided by 16.8cm in each complete rotation of the propeller, which gives us 4.99 widths per rotation.
In pitch calculation we assume zero slippage, so in this theoretical perfect situation, the propeller blade will also move forward 4.99 times the height H that we measured. So we take 4.99 x 7.7cm which is 38.42cm to give us the forward progression of the prop blade with each rotation. If we wish to convert this to inches we divide it by 2.54, giving us 15.1 inches. This is close to 15 inches, and appears to confirm that my propeller is indeed a 14x15. All our measurements are subjective, so you might get 14.9 or maybe you also would get 15.1 inches for the pitch value. But this is quick, easy, and it is as accurate as the methods using protractors, dividers, plumb bobs, deely bobbers, and other wotknots that I see online.
The formula put in its simplest form is:
(DW x π x H)/W = pitch
Enjoy!
Texasmark
Well sir you went to a lot of work and it appears that you have a general purpose low cost aluminum, maybe OEM average performance prop.
Any prop that has any pazazz, has multiple angles on the blades, aka a "complex" pitch/rake so attempting to calibrate would be best done by a design computer program.
The proof in the pudding is to run it. Nothing else comes close to real usable data!!!!!
Omineca
For anyone not overawed by computers, and who doesn't mind a little 5th grade maths, here's some further proof of this simple method. If you're not interested, then please don't waste your time reading this.
I had a second prop that came along with my boat. The PO said it was identical, but it certainly looked different. The blades looked wider for a start. No size stamped on it, just SMC 342 MICHIGAN.
So I took the measurements, as for my first prop. Diameter was obviously 14", as for my first prop, so my 75% figure and DW are identical. DW is 26.7cm.. But height H is 10cm minus 1.9cm, or 8.1cm and width W measured at 15.8cm. Putting these values into the formula in my first post gives:
(26.7cm x π x 8.1cm)/15.8cm = 43.00cm which converts to 16.93 inches.
Therefore this appears to be a 14x17 prop. Measurement and calculation took less than 5 minutes, no protractor, dividers or plumb bob required.
roscoe
Hmmmm.
I just googled the manufacturers id, "SMC 342 MICHIGAN",
took about 5 seconds.
Michigan Wheel Propeller SMC 342 14x17 3 Blade​
And you said the blades looked bigger.
So may not be the same prop design as your 14 x 15 in example one.
Now go test them out, comparing WOT rpm, gps speed, and hole shot.
Omineca
Hmmmm.
Teach a man to Google and he'll never have to think for himself
roscoe
Well, I believe the manufacturer put that number on the prop for a reason.
Title of this thread is "A quick way...."
I think the quick way is to use the part number provided.
