A1G2 Upper Unit Weep/Vent hole?
HeadAbove
Hi All,
This off-season, I decided to strip the old, hard AF paint from my A1G2 sterndrive and refinish.
In doing that, I have exposed a hole in the upper unit which I can't identify. I can't find any reference to this hole in Manual #14 or anywhere online.
I've tried to clean it out, but it is plugged with aluminum about 1/16in deep. I.e. The hole doesn't appear to go all the way through the case. But it is a perfectly symmetrical, circular hole, suggesting intention.
Can anyone confirm if this some kind of factory vent / weep hole?
Or should I fill it before I repaint?
The 1st photo is for location context. The 2nd is a close-up of the hole.
(Sterndrive s/n 1A246749)
TIA!
HeadAbove
I've since found a few photos online which show this same "dimple" on the stbd side of the gen2 upper unit.
It is perfectly in-line with the oil passage that extends from the hole with the quad ring on the LU to the top of the UU.
But after cleaning out this dimple - down to bare metal - I can see that it isn't intended to be any kind of vent hole.
So I'm assuming it is a casting artifact and will fill before repaint.
Ayuh,...... Welcome Aboard,...... I'm glad you figured it out,.....
I didn't dare to comment before, 'cause I couldn't remember,.... I thought 'bout going down to my shop to look at one of the drives there, but today is the 1st day for awhile that it's gotten above zer0,.... 10* above still ain't nice, in an unheated shop,.....
