? about bottom of boat
racefan34
yes someone told me that having your bottom painted on a boat would keep sea weed an other off of it,does anyone know if this is true?help!!! :eek:
Jack Shellac
Re: ? about bottom of boat
Yes, if you paint it with anti-fouling paint. Expensive and sometimes hard to apply, depending on what kind of boat you have.
Solittle
Yep - - With the right stuff - - By the way this section is for J & E motor problems.
JB
Moving to Boats.
cc lancer
I would not put anti-fouling paint on my bottom unless the boat stayed in the water all the time.<br />Todd, you been fishing lately? Iam just north a little ways, near Harkers Island.
SeaJayacas
If kept for long periods sitting in the water bottom paint is almost mandatory to have.
crazy charlie
If you are concerned about bottom growth you probably keep your boat in the water for more than a week at a time.If you do,then you should paint the bottom with antifouling paint to keep the growth off of the bottom.It works great.If you keep it in for less than a week at a time, you can probably get by with a good cleaning and a coat of wax before you put it in the water.Any longer than a week will usually cause growth to attach to the bottom and then you can have a mess.Charlie
waterone1@aol.com
Racefan, You did not say what type of boat you have and where you will be using it. There are a-lot of different bottom paints out there that are meant for different applications. I would suggest that you either go to a local dealer and talk to them, or find someone at a local marina that has a similar boat and ask them what they are using.
