AC voltage 1990 evenrude
Chuck4741444
I bought a 1990 evenrude 150.
I got the motor running,
Im checking everything out,
Running, I get 9.0 volts ac on ( y1, ) and 2.4 volts ac on( y2 )
Together I get 25 volts ac
I have 3 Stater plates to compare against each other for resistance,
One on a running motor, one is extra parts and the 3 is a new one for my mower.
They all comes between 6.3 and 7.5
I don't know how acute this Meyer is. But I get typical reading.
I'm not getting DC voltage, but it produces enough voltage to run with battery disconnect.
I think the Stater is going out. But I would like a second opinion
All test are at 1000 rpm.
I have a foot pedal, so I can't raise rpms and test at the same time.
I'm look for options before I start buying parts I don't need.
Thanks.
saltchuckmatt
Experts will come along but running without the battery connected ruins the rectifier.....so I'm told.
Your outboard doesn't need a battery to run though and the charge coil and the ignition stuff are totally separate.
Faztbullet
25VAC from stator is about right. You clip off top of sine wave and 12.5DC is output on red wire from rectifier.
Chuck4741444
I'm not getting getting anything from the read wire, I guess my voltage regulator is bad?
Faztbullet
Make sure the purple wire at rectifier has 12v with key on or rectifier will not turn on
Chuck4741444
Thanks, I'll check that, I had trouble with tilt and trim from the remote switch, the red plug was corroded with green stuff. I clen and go t&t working, If the purple wire runs through the red plug, i could test it there? I have manuals for my newer 96 johnson, iim flipping this motor, is the wiring color code the same?
Thanks guys.
